Computer is Bluescreening when no PS/2 Mouse is Connected
So I just bought a Razer DeathAdder to replace my Logitech 518. The 518 has always been connected through PS/2. So I remove that, and plug the DeathAdder into a USB port, because I figure it's time to move on to USB.
Start it up, and before I can even see the Windows XP startup screen, a bluescreen flashes for a split second and the computer restarts.
Attempting to boot into safe mode yields the same result. Blue screen and restart.
I did some troubleshooting and found that the only way to avoid this bluescreen was to plug the PS/2 mouse back in. I then went into BIOS and disabled PS/2 mouse support, and removed it again. Started it up, same thing, blue screen and restart. WTF? :confused:
It has nothing to do with the DeathAdder, in fact, I can have no mouse plugged in at all and it will continue to bluescreen until I plug the PS/2 mouse back in.
Explain that one, I've never seen anything like it. I'm dying to try out this new mouse, please help!
Mobo is an Asus A8N32-SLI Deluxe if it matters...
Fixed, had to disable APM, a power management option in BIOS. Dunno what the hell it has to do with PS/2 devices, but whatever.
glad you got it fixed. btw, you can have both a ps2 and usb mouse plugged into the same computer.
