Computer Help
aggpirate
Well I just put together my computer and for some reason I can get the keyboared to work. I have tried two diffrent ones. And i tested them on diferent computers so i know they work. what can be wrong?
PS/2 or USB keyboards? If USB, make sure you install at least SP1 and your chipset drivers. If PS/2... no idea. How about your mouse? Is that working? And what connection are you using for it?
It is a PS/2 and my mouse is working but it is a usb. I booted it up once and it worked fine, installed a driver for my graphics card and now when it tells me to press tab nothing happens
and it shows that it works when i press num lock but does not do anything after that.
