Hi, I'm having some problems with my computer that I built 5 years ago. Everything was fine until 2 days ago when I could not get it to power on. After pushing the button 20-30 times it finally turned on. Same thing happened today. There are power/reset buttons on the motherboard and I tried them too, but it was same.
Could this be a PSU problem or a motherboard problem?
This is my current computer :
DFI Lanparty nF4 Ultra-D
AMD Opteron 165
G. Skill 2GB DDR500
Enermax Liberty 500W
I was thinking maybe I should upgrade. I only have $150 to spend. What is the best CPU+Motherboard+RAM combination I can get with this? I only need 2 GB of ram.
Would it be better to buy a new CPU or look for used?
AMD Opteron 165
G. Skill 2GB DDR500
