Computer having trouble POSTing
Max-Powers
My computer has been working fine for as long as I have had it, then I upgraded my CPU to a 64 4000 and it worked fine. Then one day I woke up and it was at the screen with the bios logo, "hit del for bios options", yada yada. the first screen you see when you power on. I rebooted several times and it would just stop at that one screen. so I took the case off and tryed again and it worked. I thought nothing of it. had my computer on for a couple days and decided to reboot. Same thing happend again. Turned if off for several hours. rebooted several times, jiggled connections. Dbracket lights are off. (might not be plugged in, will look at that later) I took the case off, looked at it, turned it on, and it worked. Could have been the motion of moving the case to take the cover off... I dunno. Im scared that its going to do it again and stay not come back.
Whats causing this
specs in sig
