Computer goes to black screen. Need help.
HardTech
Ok I have an issue that keep popping up sooner and sooner. It started a month or so ago on supreme commander. I would play and all of a sudden the screen would go blank. The system would be non responsive and would require a hard power down.
I was ok with this, because I thought I had some memory going bad. Well skip forward to last weekend. Every time I would open any game it just died on the spot. Then it started to do this in windows. This got annoying so I went to frys and bought 2 gigs of memory.
So its in, it boots up and windows is good and loaded for a good 4 mins and its just goes black. Well I reboot and get into windows and tried running some benchmarks on it to try to see where it lies. Well memory test didn’t fail it, either did processor and HDD transfer test. But the second video came up its was gone.
I had been checking all the power rails via a monitor I have and they seemed to be fine. My mobo software reported the 12v rail about 11.86 at its lowest. All the other rails where above or at what they should be. So I don’t think its the PSU (although it would be a cheap solution). Ill list what I have now.
Vanec Stealth 550 watt PSU
Abit IC7 G Max 3
Intel P4 2.6(HT) Engineering Sample
(2) 1 gig Corsair Value PC3200
TDK DVD burner
Memorx CD-R/DVD
(2) SATA(150) 150gig (raid1) Game Drive
WD 160 gig Windows Drive
Apollo 6800 AGP
Windows XP SP2 (Install date: 5/15/2007) Dedicated Game OS
I cleaned and re-seated everything in the case, still a no go. I have heard that Apollo 6800 AGP cards had issues but I never found out the issues. No one from Apollo seems to be willing to help me. I have a feeling it’s the video card, but I have trolled the community enough to know to ask for some assistance.
Feel free to ask me anything you want, or suggest anything I may have missed. I had $1600 bill come in, and lost my job so help and a free or cheap solution is better than $1600 debt :p
PS: No errors in the log files.
i would definately be leaning in the direction that you are...PSU or video card. More than likely, it's the video card. You'll likely not receive support on a card that is likely no longer in production, and no longer under warranty. Nothing in the error log does indeed indicate a hard lock, and thus, no record of an error, since it requires a reboot. have you noticed any stuttering in video playback, or other midly intensive video (or 3D) applications? if you have, you've found the culprit. it sounds like a voltage regulator or some other component on the card is blown. are you noticing any artifacting/streaking/random off-colored pixels in 2D? these would not necessarily appear, but it does seem more likely that if the video card completely fails under 3d load, that it would also exhibit strange/erratic behavior in 2D as well.
That’s the weirdest thing about this problem I am having. No stuttering or anything leading to or during the black freeze up.
I ran a benchmark minimized in windows and it completed the full thing. Which is why I originally thought it was the video card. But then when I went to my registry settings (to get my Supreme Commander cd key) it just died.
So the oddest thing is that my monitor goes into its sleep mode, it doesn’t say it no connection. But the computer is 100% gone at this point (so its not the monitor thank god).
No the black screen while in 3d has been happening for some time now. But it would be after hours of play on Supreme Commander (and i wrote that off as program failure, supreme commander has issues period :p) And this past weekend is just broke out into this fit its in now.
Now the system hasn’t had issues per say, but I guess I should list a little more. Now I don’t think this is 100% connected but what the...
Now I have in the past have gotten the PSU replaced due to dropping rails (12v was 11.5-11.2) and I was told by Vantec "They just do that after about a year". Well its been 2 years since the replacement. Everything in the machine has stayed stable, even after I replaced the original 9600xt with the 6800 card.
Well we had something blew up our LG DLP TV and the 12v on my computer went down a bit after that. It used to stay in the 11.9 range and now as I said is 11.8 4 months down the road my HDD goes south (click of death). Now my system stays on basicly 24/7 to I chalked it up to a 5 year old drive being on 24/7.
Like I said, I don’t think anything here had anything to do with my problem now. But history on the computer none the less. Most of the products in the computer are engineering samples, or review spec samples (should matter but whatever).
Only reason why I bring up the PSU is because the 6800 agp needs that 4 pin Molex connector. I do know if its not plugged in, its not even supposed to boot (black screen). Never tried but I am sure someone here can confirm.
I have a riva tnt2 ultra sitting around (lol) so I guess I could pop that in, but not sure if that works.
So here’s my list:
---PSU---
Cons
1. .1 Rail drop after power surge
2. Connected to video card
3. Silent death of PC (can cause it)
Pros
1. Rails are within spec
2. Vantec has been known to under rate these PSU's (back in the day)
---GPU---
Con
1. Known issues
2. Year + old
3. Computer will die (100% of the time) in a 3D app
Pro
1. No issues (artifacts, tearing, discoloring)
2. Has not been tampered with
If I missed any information, let me know.
Does your mobo have integrated graphics? (I'm lazy see)
Do you have any spare video cards?
you are correct, the computer shouldn't boot if there is no 4pin power going to the card. However, I've seen a few that will. An Albatron, and an XFX...and when i attempted to run a 3D bench, they exhibited similar behavior. Double check your connections (power) to all components. Also, with these cheaper PSUs, a cheap PSU tester for $10-20 would be well spent $.
