Computer Glitching
kjm2003
Im sorry if this is in the wrong forum, but I seem to be having a very irritating problem wiht my computer randomly glitching (little .5 seconds freezes so often). Sometimes its constant sometimes it not. Has anyone every had a problem like this before? Could it be a virus possibly?
Thx in advance.
Specs:
AMD 2500+ o/c 2Ghz
ASUS A7N8X Dlx v2.0
corsair memory pc3200 2x 256
gf4 mx440
220gb of hd space
Windows xp pro sp1
If needed anymore info please ask.....:confused:
What peripherals do you have plugged into it?
Try running with just the bare bones and see if the issue is still there. by BB I mean monitor, video card, CPU, MOBO, PSU, Memory, Keyboard, Mouse. pull all other cards/printers/USB stuff off of it. the NICs are onboard, but you can disable them in network properties.
If that solves it then use a process of elimination to determine the culprit
Allrighty, I will go ahead and try that right now and see what happens... thx
well i ended up going to bone stock, and still the glichting kept up, so then i decided to just do a windows repair and that seemed to do the trick. So evberything all good and gravy now....
