Computer freezes in bios (and before)
NeuroN
When I turn it on, it starts maybe 1/5 times, when it starts it'll lock up fast.
Sometimes I get to the bios, sometimes I get to windows loading, but never further. It just stops, image freezes.
I also noticed something odd, when starting it up, if it doesen't beep in bootup (once, as an ok signal) then the ATI fan will stop after a while. When it gets further than that and crashes all fans keeps going.
I've tried diffrent memory/psu/display adapter.
Is it likely to be the cpu or the motherboard?.. I'm guessing the motherboard.
motherboard is a a7n8x deluxe
note that the computer has run smooth and without problems for ages, and suddently started this behavior.
ok simple things to try... and easily forgotten
make sure the agp card, memory, and all cables are not loose.
Especially the memory and agp card as they are the most likely culprits
You could have a bad fan on your agp card, causing it to overheat and hang the system
also, you could have some memory that has gone bad. Chack your psu if you can as it sounds like the problem may have been created by a power spike (assumption.)
A possible corrupt bios may be the issue too - (a simple clear cmos will fix that)
Good luck
happened on 3 of my machines, ITS ALWAYS stupid bios settings.. go fail safe and see if it starts up, then start to tweak settings 1 by 1, and test them every time..
@HvyMtl
I've tried diffrent memory, diffrent display adapters (including non agp) and diffrent psu. As stated in the first post.
@klowngoblin
yeah, but this started happening, this computer has been running happily on those bios settings for a long time.
ok, so it happens with other agp cards and memory? Ugh.
Check the power supply, see if it does it with a different one (if your present on is like 300-350 watts, or old, or pumping out more heat than it used to that may be the culprit, check with a monitoring program to see if any of the rails are low) Try removing all addon card except the vid card - test for stability (remove doubt that other addon card is culprit...)
Does it do it with a pci vid card? If not bad agp port... or bad bios
Do a deep bios flush - set cmos jumper to clear, unplug computer from wall, turn on power supply (to clear leftover charge) turn it back off, then remove the battery on the motherboard for 30 minutes. Reinstall and put cmos jumper back to running mode and reset your bios settings - If still no - update bios from manufacturer - if still no - try the cpu in another board (most likely not the cpu) and see if it works fine - do the same with the memory (use a memory test program to ensure no probs) agp, addon cards etc. - if all this fails to find a culprit, time to get new motherboard...
Good luck
