Hi there,
I wish to build a new PC for composition and audio processing. I plan on installing WinXP and Linux(DeMuDi) on this machine. I've included below a list of the items I have chosen for it so far and I'm hoping you can offer me advice regarding my choices. I plan on running the machine with only one fan - the PSU fan, but I will also buy 2 fans, one for the case and one for the ninja - if needed. I've also chosen items which I hope will keep my system quiet. What do you think of the choices I have made? Perhaps one of the items could be better relative to my other choices, or perhaps one of them is overkill...
Also, what about the idea of have more the one Harddrive? Besides backing up data, what are the advantages? I read the following on a music forum but i don't really understand it-
"You want to really dedicate hard drives to one purpose, your system drive will deal with the OS and the apps, another can then deal with recording and playback of audio. Due to the way that the data is needed this increase speed/track count. ideally I would go for 1 system drive (80gb) 1 audio drive (160gb) 2 sample drives in a raid 0 (2x160gb)."
Can anyone advice me on this issue, before for I set about ordering what I need? Keep in mind also that I hope to work with WinXP and Linux although I've yet to establish how useful Linux will be for my purposes. I do plan on working with audio and audio samples.
Thanks very much for your help,
Barry.
Motherboard heatsink:
*** Scythe SCNJ-1000 Ninja heatsink
http://www.komplett.se/k/cart.asp
Motherboard:
** MSI P965 Platinum Motherboard
http://www.inwarehouse.se/Product.a...=1120565
Processor:
** Intel Core 2 Duo E6600 2.4GHz Socket LGA775, 4MB, BOXED m/fläkt
http://www.komplett.se/k/ki.asp?sku=322633
Computer Case:
** Antec SOLO Mid Tower / ATX / MicroATX / Black / Silver
http://www.komplett.se/k/ki.asp?sku...13-74A15260DF1C
Harddrive:
Western Digital Caviar SE16 500GB SATA II 16MB
http://www.inwarehouse.se/Product.a...ferId=145
Graphics Card:
** Albatron/Asus GF7300GT 256M PCI-E HDTV DVI
http://www.inwarehouse.se/Product.a...=1178771
PSU:
** Seasonic S12 Nätaggregat 430W, 120mm fläkt, 4xSATA, ATX/EPS, PCI-E, 20/24pin
http://www.komplett.se/k/ki.asp?sku=323013
Harddrive:
RAM:
Kingston DDR2 HyperX PC6400 2048MB CL4, Kit w/two matched HyperX 1024MB LL
http://www.komplett.se/k/ki.asp?sku=322261
Fan (x2):
Nexus 120mm Real Silent, Fläkt, Svart & Vit, 22,8 dB(A), 36,87 CFM, 3 kablar
http://www.komplett.se/k/ki.asp?sku=316478
Barry.
Motherboard:
Processor:
Computer Case:
Harddrive:
Graphics Card:
PSU:
Harddrive:
RAM:
Fan (x2):
