computer for making data backups
S
sploiz
Guest
i work in a computer store and our main computer we use to make customer computers is failing. i knew this day would come some time because it just doesn't have enough cooling over the hard drives. i've been hoping for a case to come through that we could replace it with but none have. so we're gonna upgrade the computer and get a new case.
we don't need anything real fancy just need an intel cuz we are gonna get a core2duo for it. just a new motherboard with 4 sata ports and 2 pata ports, onboard video, nic, and sound and firewire would be a plus but not a must. and a case that can hold 4 - 6 hard drives and 2 cd roms that has decent cooling for the hard drives.
not that it matters but it will be dual booting vista and xp. i just love vista for data backups.
thank you
-neil
well i have read most of that and you see most of what is talked about is high powered or gaming rigs which is what i know about and not what i need. i was just asking about a general purpose motherboard mainly. i've been doing a lot of searching and while i was searching i thought that i would make a post also because i don't always think of everything. but i guess thanks for pointing me places that arn't much use or that i have already seen.
see the prob is that most of the newer motherboards that come with sata only have 1 ide port. and it takes a while to look through all the specs for each motherboard. so i thought there would be someone who might know of one offhand.
at first this was more of a general build question but i'm going to move it to the motherboard forums hoping they might be more considerate and helpful.
wow, your sig is soooo long.;)
bravo... who cares. your sig is 80% the size of his so i guess that would make "your sig sooo long" also. guess you gotta get you post count up somehow.
The number of PATA ports shouldn't make much difference, mainly because you can buy a seperate PCI card that runs your PATA lines, (could also facor RAID in there as well if you want,) on the cheap side they can be had for $20 or so. Are you recycling some old drives and that's why you want the IDE path or is there another reason?
As far as mas storage and cooling I'd suggest looking into the stacker line of cases with something like this in there for cooling.
or you could go with a server chasis... all depends on funding you want to spend etc...
I concur with FallenMystic. Just buy a IDE PCI Add-on card for about $20 and they often come with two IDE ports.
Also, what's your budget for the case, motherboard and CPU?
yeah. i was hoping for one that already had 2 ide ports, if not i can just use an addin card. i'm sure we have some layin around somewhere. we do a lot of data recovery for customers and i've just had better success if they are going directly to the motherboard than through an addon card. not sure why its just what i have come to find. or i can sneek in a sata cdrom and get by with 1 ide port. i think i like that idea.
we can't spend too much because we're just a small shop. i'm guessing it will come out to be $350/400 or so.
motherboard $50-100 ??
case $40 http://www.newegg.com/product/product.asp?item=N82E16811119115
cpu $125 http://www.newegg.com/product/product.asp?item=N82E16819115014
2nd hard drive $120 http://www.newegg.com/Product/Product.aspx?Item=N82E16822152052
and we have all the other parts needed
