Computer Errors Still
MattD
Trying to install windows XP pro on my newly partitioned and formatted WD 40GB hard drive. everytime i try to install it, i get a error codes.... 0x0000008e, 0x00000050, 0x0000007e...etc. all are RAM based errors, but i have gone thru 4 different sticks of ram new and old. ive ran them all thru memtest and all have failed. with the ram i am only using one stick at a time, they r all 256MB and are DDR DIMM 184-pin modules i dont know what else to do. ive installed the latest BIOS from the manufacturer, ive switched out video cards, hard drives, cd-roms, and motherboards... the only thing i havent replaced or tried to replace is the CPU. Im running a Syntax Motherboard K7SV266AD with a AMD Athlon XP 2000+ processor.... the computer has been down for months and need it working... any suggestions?
Another power supply to try??
Also give memtest86 a try..you never now :(
OldMX
this computer worked flawlessly for a long time, just put in a new motherboard a few months ago. i installed a boot screen changer and messed with that and totally messed up the computer. so i d/l a win98 boot disk and did a complete hard drive reformat and tried installing XP pro and home... both dont work, and they are orignal copies...
i have been using memtest86 with every new stick of ram i buy, they all have failed. the ram that has been in my computer for awhile now also has failed...30 errors on the old sticks and 2-3 on the new sticks.
have you tried putting the ram in differents slots.
It sounds like you either landed on some bad ram (yes all of it) or most probably your motherboard is damaged,,,
