Computer Duster + Water = EXPLOSION!
HardOCP News
[H] News
I had no idea that, if you took the stuff inside canned air and dumped it into boiling water, it explodes. If you've never seen this happen, you have to watch the video below. They also dump a bunch of other stuff into boiling water (and oil) to see if it explodes as well.
Turning liquid into rapid and powerful gas expansion...a concept since the late 1700's....And what makes it possible to pull 100 55-Ton coal cars with only water.
I enjoy this guy's videos; however his lack of precautions, at times, is very alarming. Keep cutting corners and its only a matter of time before we see him sporting an eye patch or worse.
It's not really an explosion, just a very rapid boiling. But 'explosion' is better click-bait.
If this was the case, then the other experiments they did would have also created explosions. It was only the compound in the canned air (difluoroethane) that "exploded" when it contacted water (not oil either). It was because both are extremely polar (explained in the video).
We used to take calcium carbide, wrap paper around it, and dump that into plastic soda bottles with water and recap the bottles. That was fun.
Hopefully it gets caught on video so we can watch.
I wonder if pouring some of that "dust off" liquid into hot coffee will have the same effect.
Yeah, I kept thinking that he was going to take some shrapnel from those containers. You know something is going to explode, so you put it in a glass container and have no shielding between it and you. This will eventually not end well.
While it is highly polar, and unstable, it requires an ignition source unless you reach critical pressure/temperature for self ignition. I think we are just witnessing extreme expansion due to phase change. But I could be wrong. I don't have a degree in chemistry.
It is just a rapid phase change and not combustion, the key difference is that the dust-off is also trying to dissolve into the water at the same time, pulling the dust-off molecules away from each other and closer to the hot water molecules, increasing the contact area, allowing it to heat up and expand all at once.
In the cases where there was no dissolving (the hot oil, and the other liquefied gasses), heat was only transferred within the narrow boundry layer between the 2 liquids, meaning that the liquefied gas warmed up and expanded much more gradually
Its a bit like lighting a pool of gasoline vs a cloud of gasoline, or putting a chunk of sodium in water vs. sodium powder
Me either - I'm just a developer lol.
This makes sense.
so ummm the stuff in canned air is methane gas... like in some lighters and propane tanks... it is flammable why is it a surprise that something that has a warning label keep away from heat or open flame blows up when exposed to high heat?
It's difluoroethane, not methane.
The warning label is because the can will explode if it gets too hot, and while the gas itself doesn't burn, it might degrade into a toxic gas in the presence of open flame (older refrigerants do this, and turn into phosgene gas)
43606 decomposition into glucose and can through endothermic reaction detonate. the base version looks like act mouth wash... which can be used with spun sugar to create cemtex... if the can explodes because it gets too hot that means that it reacts like nitroglycerin... or a methane explosion. methane is CHO24 fluoride is used to snag molecules that are sticking out shake that can and you have Y/\/\/\/\/\/\ or methane... then decompositiing into cold gased methane... but that means it is not nearly as much fun as using peanut oil baking power and iodized flour and too much sugar to make fairy bread... snicker. Oh I should mention my doctoral thesis was on fairy bread and my chem professor took one look at that said you your not supposed to turn food into wmds... I laughed and said how dangerous can it be? He blinked and said if I tossed calcium chporlate percolate into it would be cemtex and make take out the wall and half the building if I took at a structural or load bearing wall. My spelling still has issues but explosives are one thing I still can build in my sleep. snicker.
Just because something explodes doesn't automatically mean there was combustion involved
A container full of high-pressure liquified gas (any gas, even inert gas like helium) will explode when the pressure of the liquid/gas rises above the pressure limit of the container.
