I purchased a motherboard from the store and a case from newegg. I hooked up the motherboard in the case to what I thought was correct and tried to turn it on and the front LED blinks, all 3 fans spin for about a half second, then it all stops. When I try that again, nothing happens. It only does the blinking and fan thing ONCE unless I reset the switch or unplug and replug it in. I checked the switch hookups a couple times and those are correct. What else could be the problem?
