Computer Desk.
IanHam
What desk is this??
Ikea Jerker, i belive it has been discontinued
BEAT BY MICRO SECONDS! :D
google has the specs... go ask it for help.
I did ask google. :eek: I can only find the one with the flat table edge not the one with the little indent.
And if you didn't have an answer then why did you even post???
Odd... I asked google for the specs of the jerker and got many links that told me the same info you were looking for, dimensions. Whether it has the indentation or not is irrelevent, because the dimensions are the same.
I also asked it the specs of the fredrik and got that as well.
I'm just posting to let you know that such info is widely available. If you need more particular information, ask for it.
Here, I'll help you even more... these are the search terms I used:
fredrik dimensions
jerker dimensions
Yeah but how is it different than the Jerker?
The main difference between the fredrik and the jerker is that the jerker is deeper than the fredrik. This is obvious by simply looking at the dimensions of each desk, again, found through google.
