Problem: My computer was working completely fine, AIM and surfing the net. I clicked on a link to open a PDF file (i was trying to look at the black friday ads as posted here in the HotDeals section), and then immedately my computer turned off.
!! It turned off faster than normal, I turned it back on, and it went straight into the login welcome screen, which made me think that it went into Hibernate stage. I did not click any buttons, there was no power surge, etc. I tried to login to my computer, nothing. Restarted computer, and then it went through POST and got an error: "Could not start because the following file is missing or corrupt: \windows\system32\config\system" It also mentions how a windows repair would fix it using the windows XP CD.
Situation: I tried going into Safe Mode, nothing. I tried Last Known Good Configuration, nothing. I restored all defaults to my BIOS, nothing. I have an Asus K8V SE Deluxe motherboard using the Promise FastTrack 378 version 1.00.0.37 and the status is functional, so my array is still good. When Safe Mode starts (or tries to) it lists the files that it is loading, so when it did this, it verified that the HDs are working, but the OS is corrupt. I am using a RAID 0 configuration -- two Raptor 36.7GB 10,000RPM HDs (which I know is dangerous to begin with, but I like the speed). I JUST got back home for thanksgiving break from school, Radford University, 5 hours away. I left all of my CDs with drivers and such back at school.
Here is what im thinking: If I can get a floppy with the Promise FastTrack 378 drivers on it, I can then pop in a Windows XP CD, load them when asked at the F6 prompt, hopefully windows will recognize the hard drives and the pre-installed windows, and will be able to do a repair on it and all will be fine. However, all my CDs and floppies are at school, and the ASUS website only lists the 64 bit edition drivers. Does anyone know where I can go, or have the 32 bit edition drivers that came on the CD? Or, does anyone know a way how to fix this problem using something else? Windows repair will not work without the RAID drivers - this is my best bet to fixing the problem.
Note: My family computer upstairs, any floppy I put into the drive does not work. I get an error: "No ID address mark was found on the floppy disk." I see that one solution is to try formatting the disk(s) using full format, well I tried that and that does not work at all either. If it comes down to it, I might just have to download the drivers and load them on a floppy on a friend's computer. This is a minor inconvenience.
PLEASE HELP!!
PLEASE HELP!!
