My computer crashed and restarted itself, i opened the dump file.
What could be the problem?
Code:
Microsoft (R) Windows Debugger Version 6.5.0003.7
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\WINDOWS\Minidump\Mini121105-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: *** Invalid ***
* Symbol loading may be unreliable without a symbol search path. *
* Use .symfix to have the debugger choose a symbol path. *
* After setting your symbol path, use .reload to refresh symbol locations. *
Executable search path is:
* Symbols can not be loaded because symbol path is not initialized. *
* The Symbol Path can be set by: *
* using the _NT_SYMBOL_PATH environment variable. *
* using the -y <symbol_path> argument when starting the debugger. *
* using .sympath and .sympath+ *
Unable to load image ntoskrnl.exe, Win32 error 2
*** WARNING: Unable to verify timestamp for ntoskrnl.exe
*** ERROR: Module load completed but symbols could not be loaded for ntoskrnl.exe
Windows XP Kernel Version 2600 (Service Pack 2) UP Free x86 compatible
Product: WinNt, suite: TerminalServer SingleUserTS Personal
Kernel base = 0x804d7000 PsLoadedModuleList = 0x805531a0
Debug session time: Sun Dec 11 18:42:38.921 2005 (GMT-5)
System Uptime: 0 days 23:42:35.506
Loading Kernel Symbols
Loading unloaded module list
Loading User Symbols
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 100000EA, {88c2e3a8, 88c56008, bacdbcb4, 1}
***** Kernel symbols are WRONG. Please fix symbols to do analysis.
Unable to load image watchdog.sys, Win32 error 2
*** WARNING: Unable to verify timestamp for watchdog.sys
*** ERROR: Module load completed but symbols could not be loaded for watchdog.sys
*** WARNING: Unable to verify timestamp for hal.dll
*** ERROR: Module load completed but symbols could not be loaded for hal.dll
*** WARNING: Unable to verify timestamp for nv4_mini.sys
*** ERROR: Module load completed but symbols could not be loaded for nv4_mini.sys
Unable to load image win32k.sys, Win32 error 2
*** WARNING: Unable to verify timestamp for win32k.sys
*** ERROR: Module load completed but symbols could not be loaded for win32k.sys
*** Your debugger is not using the correct symbols ***
*** In order for this command to work properly, your symbol path ***
*** must point to .pdb files that have full type information. ***
*** Certain .pdb files (such as the public OS symbols) do not ***
*** contain the required information. Contact the group that ***
*** provided you with these symbols if you need this command to ***
*** work. ***
*** Type referenced: win32k!DEFERRED_WATCHDOG ***
Probably caused by : nv4_mini.sys ( nv4_mini+6ff2f )
Followup: MachineOwner
