computer cleaning
hijynx54
Need to clean my computers, but have no desk space. Is cleaning it on my wood floor an ok alternative? Or is it better on a towel/other type of surface? Thanks
I always lay the case on a towel or something so I don't scratch up the surface of whatever I'm working on.
If your worried about static then the wood floor is fine, but I would be scaried to damage your floor. Do it on a table
Wood is better than a towel(as far as risk of static discharge goes). Though if you aren't going to be taking cards out and laying them directly on the towel then it most likely won't matter.
