Computer Build, Your Recommendations
jweller13
Your opinion, recommendations on this gaming system I will be buying.
  • CAS: CoolerMaster Mystique 632 Tower 420W Case
  • CPU: E6700
  • FAN: CoolerMaster Liquid CPU Cooling Fan System Kit + 2 EXTRA CASE FANS
  • MOTHERBOARD: Asus P5N32-SLI Premium/WiFi-AP nForce 590 SLI Intel Chipset LGA775 Supports Core 2 Duo CPU FSB1066 DDR2 Mainboard w/Dual GbLAN,USB2.0,IEEE1394, 7.1Audio,&WiFi
  • MEMORY: (Req.DDR2 MainBoard)2GB (2x1GB) PC6400 DDR2/800 Dual Channel Memory
  • POWERSUPPLY: Thermaltake ToughPower 750 Watt Power Supply - SLI Ready
  • VIDEO: 2 NVIDIA GeForce 7900 GTX 512MB 16X PCI Express
I can spend up to $3500.
Are these quality components, are there any flaws or incompatibilities?
I do not want to build my own (not experienced) but I want lots of component options so I chose this from Cyberpower. Although, their support seems to be rated as very bad.
