Computer Build Trouble... either MOBO or PSU
GregMior
I'm having trouble with a build, and can't seem to fix it. Thought I'd ask here if anyone had any insight.
Just upgraded my computer, and giving my mom the old, only problem is, i can't get it to turn on. Everything is in properly, and connected correctly (as far as I can tell). When i plug in the power, and flip the switch on the back of the power supply to on; the lights come on for a half second and the fans spin for a half second. Hitting the power button on the front of the case won't start it, and I am at my wits end with this thing. I thought maybe I had some of the case wires hooked on wrong, but I've tried several combinations and they are on just fine (i mean the power sw, hdd led, reset sw, etc.).
Do you think I might have wrecked the MOBO with a static charge (i don't think i did, but you never know), or do you think its the PSU?
Its a crappy generic PSU that came with the case, but should be more than enough for my mom, since she doesn't do anything but surf the internet and check email.
Thanks,
Greg
grounding, its your PSU
I had this problem a couple of times with cheaper generic PSU's. The grounding in them is almost crap, and they dont ground properly.
There could also be a possibility of loose seating. Check all your preph's and see that everything is situated properly in there slots, also move some around and see if a PCI slot is causing dificulties.
Thats my 2cents
do you have an extra standoff under your mainboard? something is shorting, could be in your psu, try swapping it out. check your cables for loose connections, bare wires, missing pins, etc. take your mainboard out of the case, only leave in cpu, ram, vid, and try to stoke it up.
now that you mention it, i may have an extra standoff in there, gonna try that... thanks!
Well, i remounted everything and took out the extra standoff, still doing the exact same thing. I am going to order a new PSU, since that seems to be the consensus of whats wrong. Any recommended brands? I've heard Fortran is good.
Well, i got a new power supply, and put it in, and its doing the same thing.
I wonder if the power button on the front of the case is faulty. Going to try another case and see if that makes it work.. it not, I would imagine there is something wrong with the motherboard.
