Hello all,
I am having a problem with my computer. My stats are in my sig. The problem started when I was playing a game and then all of a sudden the monitor acted like it was shut down. Everything else kept running inside the computer (power-wise) not sure if the computer was locked up(because I couldn't see anything), but I assume it was. Tried restarting and it restarted fine. It was running in windows for a bit until it turned the monitor/crashed again. At this point I thought it was the video card.
I then started testing everything. I thought maybe it could be the memory, so I switched the modules around and used only one of them, than two, tried different spots - computer was still not working. At this point the computer would not even post and when it would post, it would hang when I was in bios or shut down again during the boot-up process. I would start it ,power would be to everything, but the thing just would not post. I reset everything back to factory defaults in my bios - the CPU was not overheating, I checked this many times.
Now here is the odd part. I went and bought a new video card thinking that was the problem. Turned out that wasn't the problem because it was doing the same thing. I then decided to take everything off including the CPU. What I found was a lot of dust in my computer. There was dust on the motherboard and when I took the HSF off I found some dust on/around the CPU. I cleaned all of that off, reseated my CPU, and my computer booted!! YES!! I thought that was the problem. Had it running prime95 and looping 3dmark. This lasted for about 4 hours until it crashed again!! WTF!! Now it is back to not posting ...*sigh*
I do not know what the problem is but I narrowed it down to the mobo or CPU. Dust might also have something to do with it, but I do not know !?!?
Any help is greatly appreciated,
Thanks!!
-fro
Thanks!!
-fro
