Computer boot up problems!
wtiberon
I just got done building three computers. The first two worked perfectly but the third is having issues. When I first boot up I started the setup for Microsoft XP and it began normally then froze. After I reboot the computer I get the bios flash...post...some white pixels...then restart. Any ideas?
Try a single memory stick.
If you can get into the BIOS, set the memory voltage correctly then try more sticks.
Tried to use one ram then switched it. The bios only has volts up to 1.95 and the ram uses 2.3v. However the other builds are identical and aren't having any issues.
Any other ideas?
Try memory from the other machines, you may have come across a set that needs that higher voltage, it happens.
I'm not saying its a memory issue for sure, but its working towards getting basic function.
