Computer and Projector for Business
shmitty
The important thing is underlined,
My aunt and uncle own a Fire Place installation company in Columbia, MO and they travel to a few large shows a year to show off their fire places. They are tired of lugging around 3 fireplaces across the country setting them up then not even getting to light them up so what they want to do is display videos of all of their fireplaces on a Projector or LCD for people to see during the expos. I've looked through the projectors and decided on this one,http://www.pricegrabber.com/p__Acer_PD726W_DLP_Projector,__26585974 I'm just not sure if this is the best bet or not, I know that they need high Lumen and a good contrast ratio so this seemed like the best one to me but I'm not sure if even 3700 Lumen will be bright enough for something like an expo center. If that is the case they will have to go with an LCD but my uncle would rather have a projector for traveling and because the booths are 10*20 feet and you can throw a really large screen with a DLP at that distance. Money isn't too much of an issue but they would like to keep the cost down. I'm also building them a computer to go with this and it is as listed, if you thing anything needs to be different please let me know. I do like the lanbox for portability for them. I cousin their Daughter will also be using it for Adobe and design things for their products. I will also put Windows MCE on it.
Case Thermal Take Lanbox 140.00
http://www.xoxide.com/thermaltake-vf1000swa-lanbox-case-silver.html
Power Supply Corsair 520w 106.00
http://www.pricegrabber.com/p__Cors...X_EPS12V_PS_2_MODULAR_POWER_SUPPLY,__23027360
Processor C2D E6400 223.00
http://www.pricegrabber.com/p__Intel_Core_2_Duo_E6400_Dual_Core_Processor,__22879558
Ram 2GB GSkill 215.00
http://www.newegg.com/Product/Product.asp?item=N82E16820231098#spec
Motherboard mATX GigaByte GA 945 94.00
http://www.pricegrabber.com/p__GigaByte_GA_945GM_S2_Motherboard,__23165461
Video Card XFX 7900GS
http://www.pricegrabber.com/p__XFX_GeForce_7900_GS_Video_Card,__29777530/search=7900+GS
DVD Burner Dual Layer 16x 42.00
http://www.pricegrabber.com/p__Lite_On_SHM_165H6S_Dual_Layer_DVD_177RW_Writer,__16593112
Hard Drive 160GB Seagate 64.00
http://www.pricegrabber.com/p__Seagate_Barracuda_7200_9_160GB_Hard_Drive,__19745918
the more lumen's the better
that I understand so based on that the 3700 Lumens of the projector I listed should work then? Due to them wanting to display fires lit inside fire places and nice pictures I also wanted a high res. and high contrast ratio, I have an optoma projector and it says 2300 lumens and it wasn't bright enough for my living room so we got a DLP T.V., I don't want them to have the same problem.
Should be ok if it's not incredibly bright. We have mini blinds in the classroom we close on really sunny days. If you need a great picture in super bright condition I would go with as much as I could afford, even 5000 lumen's would be better but they run from $6K up to $25K
One thing you might do is look into renting a 5000+ lumen projector at the shows, you should be able to do this for a few hundred dollars.
Brent
I thought that this belonged in the other section due to my main question being on the projector, sorry about that.
