I am using Bitspower Compression fittings on my WC rig. My question is are they supposed to be difficult to screw on once the hose is connected to the fitting? I was doing some test fitting and had a real hard time screwing down the lock screw. This is my first WC set up so not sure what to expect. Did you need tools to tighten them down or just hand tight?
Thank you..
Thank you..
