compression fittings
Modder man
how do i use compression fittings on my dtek v2 they wont fit, i know most of you use compressions what type of setup do i need to use on the block to get that to work
I think there is a list put together on XS that shows what barbs will work with each block because of compatibility issues concerning space.
well i just realized they will not fit on my res either....not really sure what to do
I have a pic of a d-tek fusion with 45's on it from years ago in my build log on XS. Its on this page if you want to see it. LINK
