Compression Fittings
they are secure as hell, but rather expensive.
Most stores that stock Euro-WC components like HighSpeedPC, SharkaComputers, FrozenCPU, IT-Trade, Vcore and such sell them up to 10/8mm-ish
As for sizes past 10/8mm, I've heard there are a bunch of them floating around on McMaster, but I've never bothered looking.
Koolance also makes compression fittings for tubing 3/8"+ and up (or at least I think they did), but I don't really care for Koolance so I don't know where to find them either.
Hmm you think its worth it? I mean compared to some $2.50 EK barb.
FrozenCPU carries Koolance 3/8" and 1/2" compression at a staggering $12 a piece.:eek:
I got mine from http://sharkacomputers.com/ for $4 each. Frozenpc.com is out of stock for the 3/8" ones. The only caveat is that the ones from sharka's have a slightly smaller ID than the Koolance ones. Not sure if this is normal, but it left me with a sour taste, I might as well use 1/4". :rolleyes:
