Compressed Air Question
Buckus
I've been using alot of compressed air lately, and the canned stuff at the store is pretty expensive ($10 for a 3-pack). I was wondering, for those who do professional computer care, what do you do for compressed air? Do you use a compressed air tank?
Something like this seems like it would be more economical and enviro-friendly than those disposable cans:
http://www.aircompressorsdirect.com/catalog/product_info.php?cPath=3_180_26&products_id=544
Any advice you can give is welcomed!
Yeah, as long as you don't mind the noise during refilling, those are a great alternative to expensive, environmentally unfriendly canned air.
I need a 3g compressor, but I don't have the room for it in my workshop...
Most ppl that come in for service get a free HSF clean out. I just use some dental floss to disloge the dust, then take it to my balcony and blow all the dust away with a straw and my lungs. Works well enough for me.
Well, if you want portable, here's something for consideration. I bought one of these a few years back (but not from CDW - blech!) and it does OK but nothing spectacular. Only problem is the pressure doesn't maintain for all that long, but it's usually good for a machine or two and a maybe a couple of keyboards before you need to recharge it.
Falcon Computers, where I work, uses a air compressor set at 40PSI. It's loud, but works great. When you go to clean it out though, watch the gun so it doesn't touch any of the parts. It can cause ESD. Also, if you clean the fans too quickly the fins will actually break off. :p
Don't forget to install an in-line filter on your air compressor to keep moisture and oil from the compressor from getting sprayed on the computer.
