I know this may not be the right place, but maybe you can help...? It's just for my new condo that I bought.
Ok... so I have my computer setup...
http://img504.imageshack.us/img504/5305/0001303cw1.jpg
The 2 cylinder speakers connect to the subwoofer unit (when music or loud noises are played, they light up). The subwoofer unit then has a remote that attaches to it and then an audio jack... which goes straight to my computer audio card (or monitor if I want my 360 to use the speakers).
Anyways, I have these 2 speakers in my ceiling (right behind my desk)...
http://img152.imageshack.us/img152/1012/celingex1.jpg
And the input for them are down a small hall, around the corner, in my bedroom...
http://img4.imageshack.us/img4/197/wallij4.jpg
General question is... how can I get the sound from my computer to come out of both my light up computer speakers AND the ones in my ceiling?
Are there any form of connectors, speaker wire, converters... to make this possible? The only problem I see is the wall jacks are a different size (banana connectors?).
