Willsonman
- Jun 11, 2005
So I finally finished my first watercooling/extreme cooling rig. I only suffered one casualty.... a Radeon X800GTO^2. Leak tested fine but then I moved the hose a little and a few drips .... BAAAH. Then I removed the videocard and wiped it all down... let dry for HOURS. Booted up and WOAH NELLY I got all sorts of chaos. Worked for about 10 minutes then lots of colourful fuzz. SO found a good deal on the forums here... Thanks lgestle...and I am now swinging on the green team. Pics:
OK, so I had to use the dremel... for the first time ever... and cut the drive cage to get the second PSU to fit int he bay... after that it was a perfect fit. The LEDs light up the res great. The third aluminum fan would not fit in the middle of the rad so I managed to use some 80 grit sandpaper on the plastic one to get it to fit right. Also the rubber grommets I got would not let the hose fit through so I opted just to remove them altogether. I dont move my case ever so I'm not worried. Yes, I know the wires need to be managed a little better. I am still playing with the pelts and debating the GPU pelt. So wires will straggle for awhile.
So onto stats. I have the gpu un-overclocked idleing at -4C and 7C on load. CPU is at 20C on idle and 22C load at 2.9 ghz with 1.55 volts. It is just a rough OC right now. I just wanted to see what I could get right off the bat. It has been a fun build. Any suggestions or questions feel free to post.
