ericlikeseatin said:wow that looks pretty awesome! where did you get the case from?
because, otherwise, it looks... terrible.corebreach said:Why do PC in Mac case mods always have lights? It really detracts from the design of the case in my opinion.
To the topic poster, you should look into making the whole wind-tunnel thing that Apple does in the original G5.
My thoughts exactly. That looks better that an actual G5koegs said:I have seen a lot of ugly G5-Mods, but this looks cool.
Even the blue light and the window supports its decent look.
scatpack said:Paint that damn Maxtor harddrive!
CrimandEvil said:Why not just peal off the sticker and buff the drive?
http://www.bit-tech.net/article/152/12
illgiveumorality said:Nice, funny how empty it is compared to my default G5 with the gigantic dual heatsinks.
Did you take the bottom plate out separating the mobo area from the normal PSU area?
edit:yes you did, but how?
I stuck a little blue fan in my G5 and I like the glow, hehe
feebleminded said:Hey, I was wondering how you mounted your motherboard in there. I don't see any mounts or anything. I took the backing out of my old case and cut it to fit, it looks nice but I am curious how you mounted yours.
Othersider said:You know, the wires actually looked better before the split loom...
Try taking it off and bundling more of them together; maybe extend a few so they can loop around less visible parts of the case.
Warrior said:but the orac3 case has like 20x more in that case then you do
FunkStar said:Personally i reckon the looming looks terrible. i'd cable sheath them instead of looming, cause it'd look neater.
corebreach said:All I can say is don't overdo the mod.
To tell the truth, my rubber bushings are glued onto the board. No fancy stuff here. Just a few small drops of good old gorilla glue. I have self tapping screws holding the mobo down to the rubber. Not the best way to do it, but it was quick, and I'm impatient. Besides, it holds, and I don't see it.MERKMAN said:1) So how did you "mount" the motherboard? Drill some pilot holds and then screw in these "rubber brushings" you speak of? I'm not sure what the "rubber brushing" would even look like, but I imagine I'd find the right location for the motherboard, pilot some holes, and use some "regular" motherboard standoffs to "mount" the board in the case.
Yes, I removed the original motherboard mounts, and placed the new mobo so that the pci and agp slots lined up. The case's slot spacing is standard.MERKMAN said:2) When you mounted the motherboard, you were able to pick a location so you can just "use" the AGP and PCI slots with those in the case? Obviously you can't use them all with an ATX board, but if you CAN use a few of them without a ton of modding, that would be sweet!
Just make sure you have sufficient airflow in the top "zone" if you plan to keep your hard drive in this location. It WILL overheat if you don't have fans to keep air circulating. Other than that, there aren't any problems really. It's just like building a pc inside a big aluminum box. Have fun and be creative. There's plenty of room.MERKMAN said:3) Any other major difficulties with the "modding" of the case for a PC? Sounds like folks have figured out the buttons wiring, so most of the hard work has been done by you pioneers.
There is no motherboard tray. There's the side wall of the case, and that's it. And ANYTHING is removable if you try hard enoughMERKMAN said:Oh, and my buddy was wondering if the motherboard "tray" is removable. I'm betting no, but I'll ask anyway.
