I thought I'd go ahead and share this build experience.
Gigabyte 965-DS3
Intel e6600 C2D
Corsair 6400C4 2GB
EVGA NVidia 7600GT
Soundblaster X-FI ExtremeMusic
Scythe Ninja Rev B
Antec P180
Scythe Kama Bay
Yate Loon D12SL 120mm fans (all)
Vantec NXP-205-BK fan controller
WD Raptor 150
Lite-on 16x SATA DVDRW
Antec NeoHE 550
Logitech Z-5550
Windows XP SP1a (SP2 ruined some things on my previous system...)
The DS3 I originally received was a rev.1 and DOA. Shipped 1/22 from newegg
There was nothing I could do to get it to post or even return a beep code.
RMA returned for replacement.
The second DS3 I received was a rev.2 pre-flashed with F10 bios.
My current settings are
9x multiplier
333 FSB
@3.0ghz
All Stock Voltage
EIST, C1E enabled
Orthos/Load temps are 50/53 under Intel TAT
Speedfan Temp2 low 40s. (I'm assuming thats NB)
I have booted stable to Windows w/stock voltages @
8x400 and 9x366
However, it quickly failed Orthos.
I'm sure I just need some voltage tweaking to get it stable at those speeds.
I have not yet experienced cold boot issues with the rev.2/F10
I did experience the disappearing X-FI problem for the first time this morning.
X-FI is in the 2nd PCI slot.
I flipped the BIOS IRQ setting from Auto to a static value, rebooted.
Rebooted it again back to Auto and it showed up again.
I'm not sure what others have decided the culprit is, but I'm going to see if I can find a static unshared IRQ that works reliably.
Upgraded from an overclocked dual Athlon XP-M / Tyan s2460 setup, which was incredibly noisy and becoming unstable.
I'm pretty impressed with the whole YL/P180/Ninja performance as far as Heat/CFM/Noise.
X-FI puts out way better sound to my Z-5500 than my old GTXP. Definitely worth it.
People may complain about poor creative drivers, but I think they've come a long way since the sblive, which I had in my BP6 rig years ago.
The overclock can definitely be better, but I don't feel I need that extra juice until I've got a better graphics card.
Gigabyte 965-DS3
Intel e6600 C2D
Corsair 6400C4 2GB
EVGA NVidia 7600GT
Scythe Ninja Rev B
Antec P180
Scythe Kama Bay
WD Raptor 150
Antec NeoHE 550
Logitech Z-5550
9x multiplier
333 FSB
@3.0ghz
All Stock Voltage
EIST, C1E enabled
8x400 and 9x366
