Complete uninstall and log for a application?
muniraj
Don't know how it will sound but I need a windows application that can track each action while a setup is installing on the machine. Where it is placing and modifying the registry location and keeping the keys. And then give a log file when the installation is done.
This came up as I found many application are not completely uninstalled and keep some traces here and there.
I need a application that can clean every single bit of file for any install.
Thanks
You can use installwatch to generate a text file with what the installation did. It won't remove anything for you, but you could then create a "cleanup" script based on the information in the text file and run that.
