iNsAnE_crAzY
- Aug 12, 2003
I'm gonna totally re-build a lot of the stuff in the system in my sig. Also i plan to overclock like mad. I have never done watercooling but i have read alot. and maybe not the smartest thing to do im gonna jump right into a TEC and watercool the TEC. I have read alot and i know i need to do something about condensation (especially where i live.) Any ways these are the parts i plan to use in my setup, any better recommendations are welcome. I plan to use 1/2 in. through out the whole thing.
MCW5000-PT - CPU TEC
http://www.swiftnets.com/products/mcw5000-PT.asp
MCW50-T - GPU TEC
http://www.swiftnets.com/products/mcw50-T.asp
JR-120 Hi Performance Radiator
http://www.dtekcustoms.com/index.asp?PageAction=VIEWPROD&ProdID=103
Bay-Rez : UV Blue
http://www.dtekcustoms.com/index.asp?PageAction=VIEWPROD&ProdID=119
Eheim 1250 Pump (317GPH)
http://www.dtekcustoms.com/index.asp?PageAction=VIEWPROD&ProdID=32
Things i dont know ( prepare for along list
-I want to get a new Radeon 9800XT but I'm wondering which one. Like does one have a better reputation for being more overclockable then another? And which is easiest to remove the HSF.
-What type of tubing and fittings do you guys/girls reccommend and where can i get them?
-I know it is proably a no but can i run 3 cdrom's 4 hdd's a radeon 9800xt, a gig of ram 6 led fans , and 2-4 Cathrodes and my tec's from my antec 480 true blue? if not would this be a good AUX PSU
S320-12 Power supply kit
http://www.swiftnets.com/products/S320-12KIT.asp
-Is it even close to possible to fit all this INSIDE the case I'm going to use the Aspire superalien
http://www.hardcoreware.net/reviews/review-172-1.htm
-As far as over clocking which memory would you guys use
XMS Pro Series TwinX1024 PC4000 or OCZ EL DDR PC-4200 Dual Channel
First person to answer all that gets a cookie!
ThanX
MCW50-T - GPU TEC
Bay-Rez : UV Blue
ThanX
