Complete Components?
topslop1
I'm planning on watercooling my NF7-S and 2600+ Mobile setup. I'm planning on getting a Spiral Poly Topped block for $35, an unpainted Pro-120 Core for $30, Danner Mag 3 for approx $50. I plan on setting up my own cardboard shroud and hooking up dual 120mm fans at approx $10 a piece. Then I'm going to get Zerex for a water addative and a Nappa radiator dye to give a healthy green glow to the fluid. T fittings, clamps, and tubing are the only other things I have to get and I'm good right? I plan on using a 1/2'' ID throughout the entire thing.
Is there anything I missed? Any components I should take a look at ? Anything I should change? Would I be better off going with a whitewater because of the $15 adapter that is available if and when I upgrade to Athlon 64?
Thanks.
