Compatible 1.5TB+ drives for adaptec 5405?
nowwhatnapster
I am looking to purchase some big & cheap 1.5/2TB sata drives that will work with my adaptec 5405 in raid.
I found out the hard way that not all drives listed as "compatible" truly are. I had a WD5000AACS drive in raid with some WD5002ABYS. I eventually figured out the WD5000AACS was causing silent data corruption and removed it from the array.
So I'm asking for any users of adaptec 5405's or similar models to share their knowledge. What drives are you using? Have you experienced any problems with them?
I'm hoping some of the cheaper non-enterprise class drives work, like the WD15EARS.
