Compatibility
Railroad
Hi,
I'm most likely getting a new setup since my current m/b is starting to crap out on me and it doesn't have the 4 holes for storm block. :(
Anyways, in their instructions for S939 board, you need this plate that's supplied with the motherboard which goes under the m/b. I'm debating whether I should get the A8N32 or the DFI NF4 SLI Expert. And on this website, it shows the back of the DFI and there isn't that plate.
So I'm wondering if I need it or do the screws just screw in to the two holes on the socket itself? And it should be the same for the Asus, right?
While I'm at it, which of the two boards would you guys recommend anyways? Both of them seem great and the Asus one is a tad bit more expensive.
Thanks.
