Compatibility with ZOTAC Z68
nasunor
ZOTAC Z68ITX-A-E LGA 1155
http://www.newegg.com/Product/Product.aspx?Item=N82E16813500069
CPU i7-2600K
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115070
I do not overclock. Is this the memory I want?
http://www.newegg.com/Product/Product.aspx?Item=N82E16820104255
Does the ZOTAC have the PnP setting in the bios to take advantage of this memory and therefore, justify the extra cost? Or will I be fine and have a stable system if I purchase
http://www.newegg.com/Product/Product.aspx?Item=N82E16820104173
The first RAM selection (PnP) is 1.5v the second cheaper alternative is 1.65v
Does this matter to the board? Stability is more important to me than performance in a new build. I experiment down the road.
Or is there a proper alternative I have overlooked?
Perhaps I should choose the stock standard 1333
http://www.newegg.com/Product/Product.aspx?Item=N82E16820139075
Thank you.
Get 1333. Cheaper; it's as fast as needed.
1.5V memory works fine out of the box. Higher voltage parts probably work fine at 1.5V on a lower speed out of the box too.
