I was on the Crucial site and they have a great little program which tells you which memory will be compatible with your system. Of course you don't have to buy from there, but you could take the specifications it gives you and use them to find compatible memory from other suppliers.
Have a look here : Compatibility Checker
Good for all those who want to know that whatever they buy will actually work .
