Benzie500E
- Jan 18, 2004
Okay the FE990 is $220 shipped from newegg:
CRT Type: ClearFlat Shadow Mask CRT
Dot Pitch: 0.20-0.24mm horizontal mask pitch
Max / Optimal resolution: 1792 X 1344 @ 68 Hz / 1280 x 1024 @ 85 Hz
Frequency: fh: 30~96kHz; fv: 50~160Hz
Features: multi-layered,anti-static screen coating, dark-tint screen and OptiClear® screen surface
Dimensions: 17.4" x 16.7" x 17.6" (WxHxD)
Manufacturer's Warranty / Phone No.: 3 year CRT, parts and labor / 800-632-4662
and the DP930 is $292 shipped, so thats a good $70 difference
CRT Type: 19" (18" viewable), totally flat aperture grille CRT
Dot Pitch: 0.24mm aperture grille
Max / Optimal resolution: 1920x1440 @ 73Hz / 1280x1024 @ 85Hz
Frequency / Bandwidth: fh: 30~110kHz; fv: 50~160Hz / 290MHz
Features: SuperBright
Dimensions & Weight: 17.4" x 17.4" x 17.6" (WxHxD), 52.5 lbs
Manufacturer's Warranty / Phone No.: 3 year limited warranty on CRT, parts and labor. / 800-632-4662
the main differences i see are the CRT type, the dot pitch, and the resolution maxes.
Can someone explain to me the difference in the two CRT types and the dot pitches? Is the extra $70 worth it?
