Comparing 2 Intel SSD's vs single SSD -R/W speed differences
I have the below drive and am thinking of buying the second link below which I can get for $100 NIB. I'm thinking of running the drives in RAID 0. The write speeds are 90/70 Mbps for the: X25-M/Intel 320 Series. I've seen other drives that have a write speeds of 260Mbps on SATA II which is greater than the combined write speeds of the two intel drives in a RAID 0 array.
http://www.newegg.com/Product/Product.aspx?Item=N82E16820167031
http://www.newegg.com/Product/Product.aspx?Item=N82E16820167047
I'm wondering if this drive isn't a better choice if I am trying to get more performance and greater capacity. I don't need the 160GB of the RAID 0 and I would prefer not having to do software RAID 0 anyway. For only $20 more than what I'm paying for the 80GB drive, is this a no brainer?
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227726
the agility drive can't handle random data, it uses async nand. skip that. their numbers are inflated by atto, they don't actually perform that well.
That's dissapointing. I'm thinking the Intel drives are lower stats but probably legitimate.
