- Feb 21, 2008
I inherited a Compaq Presario R3000 that had the infamous bad solder power problem. So I took the WHOLE thing apart, and got all the way down to the motherboard and soldered them, put it back together, and finally it would charge for more than 4 seconds. But now I can barely see the screen, and when I was pressed down the sleep button it would flicker on and off. Not sure what it is. I did hook it up to an external monitor and it worked perfectly, so it's definitely something wrong with the screen.
