Compaq NForce 1 Help...No Video??
Blazemore
Trying to bring back to life and old Compaq 6000 series (model #6020US) that was given to me (history of tower unknown). Thinking about using it as a file server for movies, music, etc. Only problem I can't get the integrated Geforce 2 to work. All I get is a blank screen, with the power led blinking, on the moniter, no video output. The fans, HD, power up leds on the zip drive / cd-rom work, and the cpu/chipset heatsinks warm. Also the power / HD led come on but after a few the HD light goes out, no OS on HD yet. So replacing / reseating parts, list of what I've done:
Reseated all pluge in wiring on the mb (power, power switch, fans etc.)
Replaced mem with crucial pc2100 that I know works
Replace mem again with off brand pc2100 mem (thinking something wrong with the crucial)
Replaced XP1900 with a XP1800 I had
installed a GTS Ultra card
installed a tnt2 card
Checked all jumpers
cleared the cmos
Checked the power_sw / rest_sw jumpers connected properly
Checked the power button, push button power on hold in power off
Thinking the reset_sw jumper not connected properly, having the same effect as pushing in and holding the reset button, which would exhibit similar behavior. I guess bad MB? Any ideas of things to try :confused:
Never having owned a board with on-board graphics before, I'm not really sure what to tell you. Just had one question. After installing a PCI or AGP card, did you disable the on-board graphics in BIOS, or is that even possible with your system? I've heard where people have problems with on-board audio too, when trying to use a SoundBlaster or Audigy card, until on-board audio was disabled. Are you even able to get into BIOS? Just a thought, for what it's worth.
Another thing, as for the reset, did you try turning around the plug to change polarities to the board? I've done installs where just having the board Reset/HDD/Power, ect. wires turned around would cause something similar. Once I'd did a 180 to the plugs, everything fired up.
You've probably thought about this stuff already and I'm not implying you don't know what you're doing, only grasping at an attempt to help.
After trying both agp cards, there is a jumper at the top above the agp slot, I tried that thinking the same as you, but nothing happened. As for the bios I can't get anything to post on the monitor either using the onboard video or an video card. As for the rest/power ect. jumpers are in a single jumper block (kind of like a hd ide end) where it hooks in to the mb. So you can't really install this wrong becasue in the jumper block has a space where there's not a hole for a pin, that corresponds with the jumper missing in the two rows of jumper pins on the mb. But I did try to install this block a different way, but this would lead to bending or breaking a pin off.
I'm going take the mb out of the case tonight and see if its touching the case, causing a short or something? All the cap, res, on the mb look fine, the tower itself looks new, no dust etc.
Also I'm going to try and short out the power jumper, thinking something could be wrong with the power button or jumper block? Hate to trash the computer :(
Having always built my own computers, I've never seen one with an all-inclusive header and plug like that before. All my wires are terminated for a specific purpose but I woudn't try putting the plug on in a different order or bending any pins if this was the case. You may just really fry something.
Did you try to see if there was an Online manual or something that shows the jumper configuration for the Mainboard? I haven't looked up the Compaq 6000 series (model #6020US) on the Compaq Site but if you can find out what board is in there you may be able to download a manual for it still. You know the saying, "If all else fails, try following directions", that is if you can find some directions to follow.
BTW, there are some tips I'd just seen on the Compaq Site, including "What to do if your display is blank" and so on. Click http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&lang=en&cc=us&dlc=en&product=94059&docname=bph04760 for that one or maybe just look around for a tip or suggestion. They mention that the monitor itself may be to blame or the monitor connector. Are you using a monitor that you know works? Something I hadn't considered.
I installed the old xp1900 even with a different heatsink, hoping for something out of the blue to work, no luck. The moniter does work, one I use on the computer in sig. I'll try and look for a manual on compaq website and see if they have one or any trouble shooting guide? But from pictures I've seen of the nvidia ref design nforce, both boards look pretty much the same. I'll try to take pics...
Some pics of the mb and header I was trying to describe.
OK, so the connector seems fine, no cut wires visible. Just never seen a modular connector like that before but then I don't usually work on OEM computers these days either.
I had just thought of something. Someone once gave me a Laptop to work on, that had been sitting unused for years. When I tried to power it up, all I got was a blank screen and they swore it had worked years ago, just stopped working when they'd pulled it out again. Everything looked fine but I pulled out the CMOS battery and used a multi-tester to see how much if any of the 3.3 volts was left. It only showed up as having just over 1 volt, so I went out and got a new battery from a grocery store of all places, same model number and voltage, hooked it up and was able to enter BIOS and get that much on the screen. Their kids had trashed everything that was on the HDD but at least I was able to power up now and reinstall the OS/software. I have a gut feeling this isn't the problem but since we;re grasping anyway I thought I'd mention it. Do you happen to have a volt/ohm meter, so you don't have to run around looking for a battery that may not be at fault?
Checked the battery with a DMM, its a 3.0v battery with 3.0v's. Also check the psu to make sure its putting out the right voltage etc, no luck. Took the mb out of the case and powered up without any luck again. Well I give up, mb kick my azz, took all the drives, cables, etc anything I could use some other day out. Place it in the trash with FUBAR wrote on the case. Thanks for the help Gator! ;)
