Compaq motherboards
biru32
Does anyone know what the typical brand of motherboard Compaq uses in its Presario 6000 line?
I don't know anything about motherboards. Any good sites where I can read the 101 on motherboards?
Thanks.
The Compaq Presario 6000 line has been around for a couple of years and they (Compaq, now HP) also offered Intel and AMD versions. You would have to give more detailed info about your system before anyone could tell you exactly which motherboard you have. Alternatively, you could download programs like CPU-Z or Sandra and they will tell you exactly what you have. Do a web search for either one or head to www.download.com.
In terms of good sites for mobo 101, you can check this out: http://www.millertech.com/motherboard_faq.htm It's a little outdated, but most of the info is still good. The link on form factors is pretty useful. If you don't see what you're looking for, just ask. We're a pretty friendly bunch of geeks.
i recently got new memory for my compaq 6000 for my birthday (512 ram) and i already had 512 ram in the computer, but i didn't realize that it was divided into 2-256's.... apparently i only have 2 slots...am i missing something? or is there another appropriate slot somewhere else
Compaq & HP = use cheap OEM Asus Micro-ATX boards. It wouldn't be unusual for a board on a Compaq or HP to have only 2 dimm slots.
there's 2 side by side.....and nothing else that looks like them....is there any way to make this third card effective?
NOPE. Better off returning it for a single stick of 512mb ( if the motherboard even supports over 512mb :p ).
