I have an old Compaq Deskpro which I tried installing Windows XP Pro/Windows 2000 on, but to no avail. The specs are AMD K-6 400, 192 Megs of Ram, WD 20 GB Hdd. When I put in the XP or 2000 CD, it boots from it and I select reformat. Once its done formatting, it goes to the screen where it installs the setup files and then reboots. Once it reboots it boots from the
CD again and goes to the same screen as before instead of showing me the XP/2000 Logo and finishing up installation. If I take out the XP/2000 CD and reboot the computer, it says Operating System Not Found. I would really like to get this computer running and would appreciate any help or ideas. Thanks
-Roman
-Roman
