horseflesh
- Feb 25, 2005
I have an Antec Sonata case, and the IP35-E motherboard, which has the CPU socket pretty close to the edge. I'd like to find a good cooler that will fit about the same footprint as the OEM HSF so I have a little more room to OC. Any recommendations?
(It should also use some kind of screw-down mount, I hope, because I $#@! despise the plastic push-pin mounting method. I have never had so much trouble mounting a manufacturer's HSF as I did with the one for my E3110.)
Thanks!
Thanks!
