compact keyboard
For the last 3 years, I've only used a laptop for everything and now I've gone back to having a desktop computer at home. I've grown quite fond of the compactness of the laptop keyboard and I'm wondering if I can get a similar one for my desktop computer. Anyone know?
Happy Hacking Keyboard Lite2 is small, and very nice.
Or the Professional 2, which is even nicer. ;)
Could also take a look at the Cherry ML4100 (aka G84-4100) boards. They can be found for pretty cheap on ebay.
EDIT: ML4100's use mechanical switches as well.
The question was somewhat vague...
There is compact with scissor type keys or compact with the standard rubber dome keys or compact with nice mechanical switches.
I recommend compact with nice mechanical switches. I love my Deck 82.
Deck 82 keyboard
This DSI keyboard is another option. It's sold as a Mac keyboard, but will work fine with a PC. And it's not cheap, but will be much nicer than any inexpensive rubber dome or scissor switch keyboard.
But if you do happen to like laptop-style scissor switch boards, you could look at one of the Lenovo Ultranav keyboards. It's a Thinkpad keyboard that has been repackaged for desktop use. They're not cheaper either -- about $100 IIRC.
A cheap ass Adesso mini keyboard works great if you don't want to spend over $40.
I use the A4 Tech keyboard and it works great for $12.99.
A very different, yet compact option are the keyboards from Typematrix. I recently bought a 2030 and haven't had it long enough to decide yet if it's for me but I do like the repositioning of the backspace keys and the fact the capslock is moved far to the right.
I am still having some issues with it but I am going to give it at least another week or two before I decide fully. They are guaranteed if you don't like it to get your money back so it's a fairly safe choice, although a bit pricer than most options. Another plus is the hardware dvorak switch on the fly that doesn't need any OS changes.
http://www.typematrix.com/
