Comp wont start
O-P-M
Don't know why I thought I could put a computer together but, meh. Anyways, I got all my parts put in and everything. Hooked the power supply cable to the power supply, heard a kind of a clicking electronic noise, but nothign happened, I hit the start button and nothing. I know the back of the power supply switch is turned on right. But nothing.. What could it be? I just need lots of suggestions to try because if I dont get this thing going, i'm gonna be reallly pissed off.
BTW this a frech comp build.
Spec:
Chaintech VNF4 ultra motherboard
1024 MB Crucial ram
Antec 480 neopower, I tried on a different motherboard and it started right up.
Seagate 80gb 7200 RPM
Radeon 7500 PCI, just using till x800xl comes tomorrow.
NEC 3500A dvd burner.
May be stupid but I think you should check to make sure everything is plugged in where it is supposed to power supply wise.
Got power from mobo! Thank god, Now to put it back in the case and figure out whats up
