comp won't POST after I open the case
IcarusSC
Twice now, I have opened my case up to do some routine dust cleaning, and both times, when I reconnected everything, the comp refused to post. I did not touch any components; just sprayed some canned air in there. Both times, I disconnected the box from the wall and left it for an hour, then reconnected and it booted just fine. I have not had any problems with crashes/BSDs/unexplained shutdowns afterwards; I just can't get it to come on like it's supposed to! Any suggestions?
I have a Gigabyte 81PE1000 Pro inside an ABS PC machine that was purchased for me.
check all the connectors, and make sure that you didn't spray any of that frozen water onto any parts ;)
