My pc was running fine and smooth, untill I decided to swap around towers to different desks. I needed the printer on one(couldnt get printer drivers installed) so thought a simple tower swap would fix the printer issue. So the computer I am typing on now is hooked up to the printer and all fine. While my pc wont boot windows.
It starts the loading bar, then restarts the comp.
So, I made sure all the connections were secure and no leaks in my water cooling loop, and I turned the pc on again. No go.
I started inspecting things, and when I turn my psu on, there is slight buz for a half a second.
And, when I get into bois, the cd rom drives and hd dont always show up....
I have a SilverStone 600Watt modular psu. Is this the problem? I could plug in a different psu from another comp, but that would take a long time. But, I will do it if I have to.
Any Ideas? Please! I begging you!
