Comp not booting up, new build, help needed
BrownThunder
I have just built a new system, and I am having trouble with it.
specs:
A64 3800+
2gb (4x512) Pc3200
Chaintech Mobo
6600GT
160GB ATA HD
NEC Dvdrw, yada yada, the usual.
I had the system up and running fine for around 2 hours yesterday, playing world of warcraft. I did a fresh install of windows, reinstalled some software, windows update, it restarted and everything just fine.
then all of the sudden, the system locks up completely, and the cpu speaker beeps like mad (internal ones, not the stereo speakers).
so I turned the system off. I turn it back on, and now everything powers up, with all the fans spinning and the LED on the DVDRW is flashing, the power and HDD LED's are constantly on, but nothing happens. No noise, no signal to monitor, no computer actually working. I have swapped out numerous parts to locate the culprit, but nothing happens differently. The same problem exists. I have tried different video cards, PSUs, optical drives, hard drives, memory, everything.
the processor is cosmetically still perfect, and has no odd smell to it, so i figured it wasnt burnt up. What could be the problem here? Is it a mobo or cpu problem?
have you tried resetting the bios then restarting it again?
are you sure your power supply is providing enough power?
you mean by taking out the battery, starting it up, replacing it, then starting it up again?
if so, yes. I am trying a new PSU now to see if that is the problem.
i tried clearing the CMOS and all, when I put the jumper cap in the CLEAR position, it makes a high pitched noise (similar to ears ringing)
in default, of course, the same thing happens.
3 PSU's tried, same problem with all of them.
