comp keeps closing down for no reason - bsod
urbantus
Recently my pc has started to crash for no apparent reason
The blue screen comes on and my pc reboots
In the event log I get this message
Details
Product: Windows Operating System
Source: System Error
Version: 5.2
Symbolic Name: ER_KRNLCRASH_LOG
Message: Error code %1, parameter1 %2, parameter2 %3, parameter3 %4, parameter4 %5.
Explanation
A blue screen (Stop error) was reported. The message contains details about the error. A matching event with Event ID 1001 might also appear in the event log. This matching event displays information about the specific error that occurred.
User Action
No user action is required.
I am also getting the following
Details
Source: Application Error
Version: 5.2
Symbolic Name: ER_USERCRASH_LOG
Message: Faulting application %1, version %2, faulting module %3, version %4, fault address 0x%5.
Explanation
The indicated program stopped unexpectedly. The message contains details on which program and module stopped. A matching event with Event ID 1001 might also appear in the event log. This matching event displays information about the specific error that occurred.
User Action
If an error report was generated for this error, you might be able to obtain more information about the error by sending the report to Microsoft for analysis.
What to expect
Microsoft actively analyzes all error reports and prioritizes them based on the number of customers affected by the error signature contained in the report. When a report is submitted, Microsoft will try to determine the cause of the error, categorize it according to the type of issue encountered, and send you relevant information when such information is available. However, because error reports do not always contain enough information to positively identify the source of the issue, Microsoft may need to collect a number of similar reports from other customers before a pattern is discovered. Although Microsoft might not be able to provide a solution for your particular error at this time, all information submitted is used to further improve the quality and reliability of our products.
And
Details
Source: MsiInstaller
We're sorry
There is no additional information about this issue in the Error and Event Log Messages or Knowledge Base databases at this time. You can use the links in the Support area to determine whether any additional information might be available elsewhere.
Thank you for searching on this message; your search helps us identify those areas for which we need to provide more information
And
Details
Source: Disk
Version: 5.2
Symbolic Name: IO_WARNING_PAGING_FAILURE
Message: An error was detected on device %1 during a paging operation.
Explanation
An input/output (I/O) request to a memory-mapped file failed and the operation was retried.
User Action
If these events are logged regularly on a primary system drive, replace the device. Otherwise, no user action is required.
Version: 5.0
Explanation
User Action
Is there any thing I can do to resolve theses problems
I ran the online seatools system check [does this work ok with amd based ststems]
here are results
Results for volume C: (NTFS)
Volume Label: Windows
Volume Size: 41.94 GB
Some files on the volume are open. This may effect the accuracy of the file system check and result in false errors.
The file system contains errors that need to be repaired.
Results for volume E: (NTFS)
Volume Label: General
Volume Size: 78.86 GB
The file system was checked and no problems were found.
Results for volume F: (NTFS)
Volume Label: Music
Volume Size: 62.92 GB
Results for volume G: (NTFS)
Volume Label: Games
Volume Size: 66.34 GB
How can I repair these systems
here is the
SeaTools Online 90 Second Surface Scan
Started at 6:17:35 PM on 9/26/2005.
Scanning drive: NVIDIA nForce4 Serial ATA Controller : ST3250823AS
Serial Number: 3ND08C9B 3ND08C9B
Capacity: 250.06 GB
Scan complete. No errors were found.
And here is Drive self test
Run: 26/10/2005 18:21:05
Model: ST3250823AS
Capacity: 250.06 GB
Test result: Self-test routine completed without error.
I also used memtest and that showed no errors
Does this mean my hard drive is ok or needs replacing
AMD Athlon 64 3500+ Winchester 90nm (Socket 939)
Asus A8N-SLi nForce4 SLi (Socket 939)
Corsair 1GB DDR XMS3200C2PT TwinX (2x512MB) CAS2
Gigabyte GeForce 6800 GT 256MB DDR3 TV-Out/Dual DVI (PCI-Express)
Seagate Barracuda 7200.7 Plus 250GB ST3200822AS SATA 8MB Cache SE)
Pioneer DVR-109 16 x 16 DVD±RW Dual Layer ReWriter -
Creative Sound Blaster Audigy 2 ZS 7.1 THX Sound Card
Enermax noise taker600w psu
Win xp pro sp 2
