comp just randomly restarted
BSOD possibly
I love how the default setting of XP is to restart instead of telling you it's crashed. Sure, it doesn't show a BSOD- "No more BSOD's"... but it still crashes.
You can turn off the automatic restart.
Right click My Computer -> Properties -> Advanced
Click the 'settings' under 'Startup and recovery'
Unselect 'Automatic Restart'.
Now, if you crash, it'll at least BSOD for you and tell you why. You'll usually have to restart anyhow, but at least you know you restarted and it's not bizarrely resetting itself.
Yes, CD drives can cause BSOD's, happens with mine on occassion, I get a KERNEL_STACI_IN_PAGE_ERROR or something of the sort.
2k pro/XP, makes no difference, they're both set to restart without halting by default.
You must be very new to the Windows world if you don't know what a BSOD is. Blue Screen of Death. When something goes wrong with Windows, like say, a memory error, the screen turns blue and tells you windows did something stupid or something happened and you have to reboot.
my montiro doesnt turn blue, it just says there is no connection with my comp,as if the computer wasnt on.
yep, that happened when i put in my bootleg hulk cd i got from Turkey. u kno dat bsod happened to bill gates when he was presenting windows 98
i was lmao.\
